sACN Output Viewer [Tab 37]
This display allows you to check current live outputs on a universe-by-universe basis.
sACN Output Viewer can be opened in a standalone tab from the Workspace Layout Menu or by using [Tab] & [3][7].
Overview
The left side of the viewer is the universe grid. It displays 512 address cells. Cells outlined in a color are currently patched addresses. Each patched cell contains an address number and output value. Unpatched cells are black and only have an address level.
Output values are 0 through 255. 0 is displayed in black and 255 is in bright red. The red output value color will grow brighter as the output value increases.
If there is a channel or address selection on the command line, the appropriate address cell will be outlined in gold. You can also press on a cell to select it but it will not post to the command line. Information about the selected address will display to the right of the grid.
Any available sACN sources will be displayed in the right panel, and are color coded. The address cells will use that same color coding to indicate the device it is patched to.
Configuration Options
When the Follow Command Line box is checked, the viewer will follow the command line for selecting addresses. This is enabled by default.
Press {About} to open the About Address display in the CIA.
Press the left and right arrows to scroll through the available universes, or enter a specific universe number in the box.
